TYROS 332 BC
The ancient Phoenician town, fleet and figures, as they were displayed at the First Dioramica in 2016, are part of our DBMM gaming system representing the campaigns of Alexander the Great. Hundreds of Macedonians (not displayed here) are already painted by Mr. Bos. All of it is still under construction. Sandy table cloth and plastic water sheets will be replaced in the future by large transparent water & rocky coastal sections running all around the island town. The town will be enlarged and some Bronze Age Hittite and Medieval Byzantine sections will be replaced by Phoenician and Classical Greek ones.
Zuletzt geändert von Cryns am Mo 23. Apr 2018, 09:17, insgesamt 1-mal geändert.
Re: Tyre 332 BC
Only a 6th c. BC bireme produced by Dusek wood ship models is not finished yet and will be added to the fleet later on.
ANCIENT MEDITERRANEAN MERCHANT SHIPS AND CARGO VESSELS
Ancient harbours and war fleets usually contained more cargo sailing ships than oar-propelled galleys.
Those ancient Greek sailing cargo ships are totally absent in the existing 1:72 scale ranges.
There is not one pre-Roman cargo ship on the market, only in much smaller or larger scales.
During my trips over the years I visited countless Greek souvenir shops to look for ancient ship models. I found just ONE in about the right scale. I was so excited, I offered the shopkeeper to buy her complete stock. But it turned out that ship was the last and only one available....
Figures, cargo and planking pattern of the hull are added by me. The poor quality of this hardboard model (best expressed in its heavy mast and yard and the giant rigging blocks) made me decide last winter to start building my own range of Classic Greek cargo ships together with their 1:72 scale crews and cargo bulks.
Zuletzt geändert von Cryns am So 13. Aug 2017, 12:54, insgesamt 1-mal geändert.
Re: Tyre 332 BC
Von Deinen tollen Gebäuden war ich schon auf der DIORAMICA vollauf begeistert !
Re: Tyre 332 BC
Thanks for your nice words, my dear Egyptologist and Hermannschlacht expert Carnuntum.
BUILDING THE KYRENIA SHIP FROM SCRATCH
The Kyrenia shipwreck (also called Kerynea in Greek), was found off Cyprus' northern coast. A 14 meters long merchant ship from the 4th c. BC, thus perfectly representative for Alexanders era.
A full size replica has been build and tested by nautical archaeologists:
http://4.bp.blogspot.com/-TNDZinLMBBE/U ... nia+II.jpg
http://www.ancientshipwrecks.com/wp-con ... CF1227.jpg
Several scale reconstructions are displayed in museums:
https://s-media-cache-ak0.pinimg.com/73 ... -ships.jpg
http://www.my-favourite-planet.de/image ... t-ship.jpg
A wooden model kit is for sale in scale 1:43
http://keywordsuggest.org/gallery/372334.html
Several 3D models are available too.
https://www.turbosquid.com/3d-models/3d ... del/686451
But specialists convinced me in the case of 1:72 3D printing the texture of planking and canvas will get lost and the full sails won't work out correctly.
So I collected 3 different building plans of this same ship, all of them showing minor variations. All 3 of them are printed in full scale 1:72 which makes the construction of the model much more easy. Because for tabletop gaming purposes, a flattened bottom is needed, made of vintage oak creating a strong base. Prow and stern pieces are cut from used beech wood paint-stirring-strips. Shape and size are exaggerated so can be corrected and fine tuned when the basic construction is finished. Temporary hull skeleton made of balsa-multiplex so easy to work and push pins into by hand.
Zuletzt geändert von Cryns am So 13. Aug 2017, 12:50, insgesamt 3-mal geändert.
Re: Tyre 332 BC
All sawing and cutting is by hand, no machines used, just like the ancient shipwrights did it.
Fine tuning of the rounded hull is mainly a matter of sanding based on bare eye judgement.
Re: Tyre 332 BC
Planking of the hull starts with the upper ones directly under the boards.
Their exact positioning is critical for the whole further development of the model. Just like the ancients did it, the ship is build hull-first, the inner ribs are attached only after the full hull is finished. (This technique was used until the Byzantine era.)
That means the planks are not attached to the temporary skeleton, only to each other. For the first plank that is very tricky: it can only be fastened at prow and stern tips and has to be kept in position by rubbers and pins until a second plank is glued below it.
As soon as the second and next planking is added, these are glued together using lots of clamps.
Re: Tyre 332 BC
To give the planks their right shape, the wood is softened by hotwatersoaking.
The soaked wood strips are bend into shape by using a thermal bending iron.
Both tips but also full lenght top and bottom of each plank is cut and sanded to achieve exact connecting angles. The result is a very messy exterior surface that has to be adjusted later on.
Re: Tyre 332 BC
After full length planking is ready, triangle area's at lower bow and stern have to be covered up.
A rough hull is ready now so the temporary skeleton can be removed
Re: Tyre 332 BC
Wonderful so far!
Re: Tyre 332 BC
Thank you Kostis.
The oak bottom sheet is hollowed to suggest the inner bottom structure of the hull. From the outside it looks like a flat bottomed tabletop model.
From the inside it should look as much as possible like a full hull reaching under the waterline.
The temporary skeleton is removed.
Inside and outside of the planking is sanded up to a hull thickness of 2 milimeters.The oak bottom sheet is hollowed to suggest the inner bottom structure of the hull. From the outside it looks like a flat bottomed tabletop model.
