Beitrag von dirk » Di 26. Jul 2022, 18:18
Dein "Archaic Greek Merchant Ship" hast du sehr schön fotografiert. Mir gefällt die Darstellung. Auch die Bemalung deiner Figuren und Schiffe finde ich schön. Die passt sehr gut zu den antiken Figuren und Schiffe.
Dein neues Schiff sieht natürlich auch wieder toll aus.
Beitrag von CHRIS DODSON » Mi 27. Jul 2022, 06:02
Mr C.
If your standard gets raised any further I will have run out of words to praise you!
Beitrag von Cryns » Do 25. Aug 2022, 11:32
Thanks for your beautifull words dear Stenfalk, Dirk and Chris.
this summer I worked very hard on the modelkit of the Merchant Galley:
Merchant Galley moldbed.png (714.14 KiB) 669 mal betrachtet
Merchant Galley Mold2.png (1.07 MiB) 669 mal betrachtet
Merchant Galley Steel Rod Reinforcement.png (787.95 KiB) 669 mal betrachtet
The mast has been reinforced with extra care.
In my last models the mast was still too flexible because the 1mm steel rod bent during the rigging.
Now I used 3mm steel rod of which the tip has been narrowed to 1mm with a grinding tool.
Additionally, this typical 6th century BC Greek mast needed a metal reinforced loop to hold the lifts of the sail.
Steel Rod Reinforcement.png (806.37 KiB) 669 mal betrachtet
Merchant Galley test Cast .png (639.81 KiB) 669 mal betrachtet
The first six attempts to fill the mould with resin were not succesfull.
The mould is very big and my resins potlife is shorter than the time it needs to infiltrate all canals.
I cut more and more canals until the farest (and most upper) parts of the mould were filled with resin.
Merchant Galley Cast additional resin canals.png (702.95 KiB) 669 mal betrachtet
Zuletzt geändert von Cryns am Fr 26. Aug 2022, 10:27, insgesamt 2-mal geändert.
Beitrag von Cryns » Do 25. Aug 2022, 11:37
Resin Parts Merchant Galley .png (964.44 KiB) 668 mal betrachtet
Merchant Galley resin model small.png (919.94 KiB) 668 mal betrachtet
Manual p1 merchant galley.jpg (149.69 KiB) 668 mal betrachtet
Manual p2 merchant galley.png (412.58 KiB) 668 mal betrachtet
Merchant Galley rigging plan.png (408.61 KiB) 668 mal betrachtet
Beitrag von dirk » Mo 29. Aug 2022, 19:20
A fantastic ship an excellent details - wonderful !
Beitrag von stenfalk » Fr 2. Sep 2022, 21:03
Ich bin begeistert!
Beitrag von Cryns » Di 6. Sep 2022, 10:02
Thank you Dirk and Stenfalk for your nice words.
Beside the rowed version with reefed sail, I made a sailing version with full sail of the Merchant Galley:
Merchant Galley Full Hull and Sail Text kopie.png (815.75 KiB) 505 mal betrachtet
Beitrag von Cryns » Mo 19. Sep 2022, 09:33
Set 3 of the Ancient Greek Sailors is painted for presentation and available.
CM-007 Ancient Greek Sailors Set 3 klein.png (959.95 KiB) 384 mal betrachtet
This set was disigned for crewing the Gyptis boat with sitting sailors. Punting men and climbing men were added to make a full set.
http://sfac-info.fr/wp-content/uploads/ ... ourtal.jpg
Beitrag von DirkB » Mo 19. Sep 2022, 18:06
Wunderschön modellierte Figuren, welche auf die speziellen Arbeiten auf einem Segelschiff abgestimmt sind. Ein Meisterwerk der Recherche und Umsetzung.
Beitrag von dirk » Sa 24. Sep 2022, 16:56
Wieder sehr schöne Figuren von dir, die auch wieder wunderbar zu den tollen Schiffen passen.
