Beitrag von Cryns » Fr 15. Apr 2022, 16:10
Frankzett hat geschrieben:
Do 7. Apr 2022, 12:34
In 72scale the interscalium of the Olympias, from bench to bench / oarlock to oarlock, has around 12mm, what is the measure between your oarlocks?
The measurement in my shipmodel from oarlock to oarlock is 14mm.
Though I am aware in the old literature a space of 1 meter per rower is usually given which should be around 12mm.
I had two reasons to add extra milimeters.
Most important is my figurines are too big. They simply don't fit into a 12mm space, which I discovered when I build my first rowing boat.
Like most other 1:72 figurines, mine are between 23 and 25mm instead of between 20 and 23mm.
Also I read a theory making a difference between a wargalley and a merchantgalley.
For the wargalley like Olympias every centimeter of space reduction is advanteous in an attempt to cram as much musclepower in a shiphull as possible.
With a merchantship, this was less important since such wide hulled galley was not very fast anyhow and did not have to ram an enemy ship.
I designed this ship with the 'start of stroke rowers' in mind. Most of them fit banks, oars and feetrests pretty well.
Start of stroke.jpg (189.45 KiB) 1450 mal betrachtet
The 'end of stroke rowers' fit too. But less perfect. Also their arms position must be lowered. Which is possible since its soft metal including partly separate arms:
End of stroke.jpg (198.77 KiB) 1450 mal betrachtet
Beitrag von Wolfgang » Sa 16. Apr 2022, 07:01
Das sieht sehr stimmig aus! Perfekt gemacht!
Beitrag von Frankzett » Sa 16. Apr 2022, 09:41
With Your 14mm and the wide benches, You can shift the figurines in the correct position. So there are some "invisible" tolerances with the measures which deletes some inaccuracies. I think this is clever, it fits very well.
Beitrag von Cryns » Mi 11. Mai 2022, 10:03
Thank you Wolfgang and Frankzett.
Aiming at some customers who are primarily intersted in the nautical aspect of shipmodels (and not in flatbottomed waterline ships embedded in epoxy water with figurine crews on board) I cast an additional resin bottom for hull and keel for the Holkas Merchant ship, looking like this:
Holkas ancient Greek merchant shipmodel with keel text small.png (989.5 KiB) 1282 mal betrachtet
Beitrag von stenfalk » Mi 11. Mai 2022, 14:56
A dream made of resin! You're one of the most ingenious shipbuilders of antiquity, I have to give you that!
Beitrag von Frankzett » Do 12. Mai 2022, 10:57
Great work with this whole rigging. I see the whole time, work and patience was worth of it.
entrauner
Beitrag von entrauner » Do 12. Mai 2022, 14:21
killer diller model in all aspects!-congratulation!
Beitrag von dirk » Do 12. Mai 2022, 19:40
The ship looks really fantastic. Excellent work !
Beitrag von Cryns » Di 17. Mai 2022, 15:32
Thank you so much dear Stenfalk, Frankzett, Entrauner and Dirk, for your nice words. :D
Stenfalk, I painted your Shami goats because I planned to add them to my Holkas ship as part of the cargo, on their way to a far Greek Colony.
I had not made up my mind to place them at the bottom floor of the hull, on the front deck or in a cage placed upon the beams and other cargo.
Shami Goats Stenfalk.jpeg (88.48 KiB) 1134 mal betrachtet
Shami goat Stenfalk.jpeg (66.28 KiB) 1134 mal betrachtet
Now this ship is finished, I am adding the crew and I ask myself where to place those animals. Its pretty stuffed already.
Holkas total back.jpg (211.5 KiB) 1134 mal betrachtet
Holkas top back.png (924.17 KiB) 1134 mal betrachtet
Holkas top bridge kopie.png (998.26 KiB) 1134 mal betrachtet
Holkas hull cargo kopie.png (1019.26 KiB) 1134 mal betrachtet
I have to waite for my next, bigger boat I think.
Zuletzt geändert von Cryns am Mi 18. Mai 2022, 07:52, insgesamt 1-mal geändert.
Beitrag von CHRIS DODSON » Di 17. Mai 2022, 16:12
Mr C.
That model is exquisite.
