Beitrag von Cryns » So 10. Mai 2020, 12:11
Here is some pictures of what I made in february-march 2020:
A piece of fine cotton soaked in bone-glue is streched on a bag of sugar:
sail on sugar bag.jpg (307.95 KiB) 549 mal betrachtet
The front of the sail is finished by sueing ropes both horizontal as diagonally. The joints will be covered by half rings later on.
half full sail.jpg (312.8 KiB) 544 mal betrachtet
A layer of compound is added at its back to give it all more volume before the second piece of cotton is added at the backside of the sail.
adding volume mass.jpg (337.49 KiB) 549 mal betrachtet
To make the backside cotton look like the frontside one (vaults for the crossing ropes at the front) a fake rope crossing pattern is added before the backside cotton is added.
adding fake ropes.jpg (349.99 KiB) 549 mal betrachtet
With both cotton layers attached to the yard, it is bend in the right shape to reproduce the influence of the wind on the textile and the wooden poles.
bending yard.jpg (290.21 KiB) 549 mal betrachtet
The same is done with the top edge of the sail: the wind is pressing yard and sail away from each other, creating gaping holes between every joint.
Since it was not possible to put enough tension on the sail to make this appear naturally, it had to be achieved by using lots of pins instead.
opening space between yard and sail.jpg (388.09 KiB) 544 mal betrachtet
Beitrag von Cryns » So 10. Mai 2020, 12:53
A new half full sail and a new raised sail were made this way:
half full and raised sail.jpg (326.96 KiB) 542 mal betrachtet
For the raised sail, a lot of slits had to be closed and filled up with compound to enable casting and, more important, releasing the resin casts from the mould.
raised sail.jpg (287.28 KiB) 542 mal betrachtet
Moulding and casting was done just like it was with my two large sail designs:
embedding compound.jpg (323.48 KiB) 542 mal betrachtet
first silicone halve.jpg (299.43 KiB) 542 mal betrachtet
silicone halve for the half full sail.jpeg (132.41 KiB) 542 mal betrachtet
resin copy.jpg (78.73 KiB) 542 mal betrachtet
One of the great advantages of making sail masters in textile instead of sculpt them with compound or putty is that the cotton texture keeps visable.
This makes it easy and succesfull to paint and still look like a canvas sail.
half full sail close.jpg (239.34 KiB) 542 mal betrachtet
half full sail.jpeg (148.49 KiB) 542 mal betrachtet
Beitrag von CHRIS DODSON » So 10. Mai 2020, 12:57
Hello Mr C.
I must say your imagination and creativity seems to have no limits.
Fantastic and truly inspirational modelling.
The word genius comes to mind !
Ps. The roof is repaired but I am now worrying about the others.
Beitrag von Wolfgang » So 10. Mai 2020, 15:04
Das ist wirklich genial gemacht. Sei es die Technik, sowie die Materialien, die du verwendest! Du bist einfach ein fantastischer Modellbauer!
Beitrag von stenfalk » So 10. Mai 2020, 19:47
Well, what do you want to say in the face of such results? For me personally, the admirable thing is this ability to deliver top performance not only in one area, but across the entire range of requirements. Research - world class! Create master models - world class! Create silicone molds - world class! Resin casting - world class! Prepare building instructions - world class! If you're looking for a role model, here it is.
Beitrag von Egbert » Mo 11. Mai 2020, 07:42
Wow Cryns...
Outstanding, masterclass modelling! :o
Thank you for sharing your work with us and showing us how it's possible to make something like that.
For me it's incredibly great what you're producing.
Beitrag von DirkB » Mo 11. Mai 2020, 19:47
Hello Cryns,
Thank you for the step to step guide. Very interesting. Great topic. It's not quite my era, but your implementation is masterful.
Greetings Dirk
Beitrag von Cryns » Mi 3. Jun 2020, 15:02
Dear Chris, Wolle, Stenfalk, Egbert and DirkB thank you so much for the fantastic replies.
ANCIENT ROWING BOATS
I have finished the sales showmodels for my 3 new ancient rowing boats.
Crynsminiaturen Rowing Boats 2020.jpg (121.77 KiB) 275 mal betrachtet
These are crewed by a variety of my Greek sailors, paddlers and rowers.
The large one has two benches and space for 4 rowers plus a helmsman for the steering oar:
Rowing Boat Large Product Shot 2 kopie.png (835.89 KiB) 275 mal betrachtet
A difficulty that was faced by Alex Gusev and other designers before me, was to make the rowers fit the benches.
Ancient sources mention a distance of about 1 meter between every oar/bench.
In the reality of 1:72 modelling this would be 13 mm.
But for most poses with stretched legs, stretched arms or bending forward, 13mm is too narrow.
It takes at least 15mm to make full action rower figurines fit their seats without touching the ones before them.
Here it is even more: 16mm. Thats also because many of our figurines are bigger than 1:72 scale or have the length of a modern male body.
This boat was originally designed for more than 2 rowing benches but to avoid such overcrowding-trouble I reduced it to 2 benches only.
Ancient Rowing Boat Large Topshot.png (875.41 KiB) 275 mal betrachtet
Ancient Rowing Boat Large front kopie.png (819.74 KiB) 275 mal betrachtet
Ancient Rowing Boat Large insert kopie.png (879.62 KiB) 275 mal betrachtet
Ancient Rowing Boat Large topshot flute.png (915.82 KiB) 275 mal betrachtet
Ancient Rowing Boat Large drinker.png (1.07 MiB) 275 mal betrachtet
The color pattern on the boat is based upon nautic mosaics from 3th century Roman North Africa.
Rowing Boat Large Crynsminiaturen Product Shot no text kopie 2.png (777.16 KiB) 275 mal betrachtet
Beitrag von CHRIS DODSON » Mi 3. Jun 2020, 17:56
Mr C where does one begin?
Art in its finest form with super photography tricking the eye into reality.
May I respectfully suggest a Mediterranean evening light as a background ?
I envisage these guys off to fish as the sun begins to settle down for the night.
Brilliant work, inspirational.
Beitrag von Wolfgang » Mi 3. Jun 2020, 19:12
Einfach nur fantastisch!!!
